Trailing arm refurbishment.
#1 Post by MIG Wielder »
I've been cleaning up my spare trailing arm ready for new bushes ( those 3M stripping discs work better than sand blasting ! ) and I was interested to note that where the lower shock absorber bolt goes, the arm has a couple of indentations pressed in to it to widen it at this point. Having had one fail here in the past I was wondering if these indentations may contribute to future failure. Certainly you can clearly see the " press tool marks" ( I think that is what they are called).
Anyway I was wondering about getting a wide fillet of weld run down each side, where the little sticky arrows, are just to strengthen them a bit.
Is this worth it do you think ?
Thanks,
matt of the vivas
Re: Trailing arm refurbishment.
#2 Post by matt of the vivas »
I wouldnt run a straight line of weld along the line - you will just create two new weaknesses, one either side of the weld. You could box the top of the mount with a short tapered plate, from the top of the bush mount down to the start of the rolled over section next to the shock mount.
#3 Post by Jon Tilson »
Funny that....TR7 ones have a plate on top that also acts as a spring pan IIRC.
Great minds...
tamtrucks
#4 Post by tamtrucks »
if this helps,, i found this picture but cant remember where
PaulB
#5 Post by PaulB »
How do you attached the rear antiroll bar with a plate welded all the way along the arm?
whydidistartthis
#6 Post by whydidistartthis »
PaulB wrote:How do you attached the rear antiroll bar with a plate welded all the way along the arm?
Longer bolts, and some suitable tubing.
The ones I have, have the tubing attached, but not entirely sure how!...
tinweevil
#7 Post by tinweevil »
To my eyes boxing it in like that makes it worse in the area Tony has highlighted. It cannot flex along so much of it's length any flex has to be accomodated by the open section. With poly at both end the flex in the joints is reduced meaning the open section gets even more work to do.
I would think the places to box are where the sides of the channel are not parallel; The first two inches or so forward of the shock and anything you can get behind it as Matt said.
#8 Post by soe8m »
I did weld plates around the side where the shock is in and the rubber bush, axle side. Will post some pics when i have time.
