Fuel injection... on an 1850
djw113uk
#1 Post by djw113uk »
We have two 1850's. Both are ex- auto, one with sprint diff and one still with auto diff, both with 1850 o/d gearboxes. One gets 32-35mog, the other 28 sometimes worse, under the same conditions.
On the poor MPG one we have a lambda which shows rich most of the time, except when you get to higher revs when it goes lean. if you lean off the carbs it just goes lean earlier, but is still rich under all other conditions.
I could get a carb rebuild kit from Burlen for about £80, but after putting efi on my rover 3.5 I wondered if anyone has efi'd an 1850?
I guess megajolt is the obvious solution, but what about the inlet manifold - do you drill and install injectors on whats there, or if there another easier / better solution.
I know there are a few sprint efi's about, but has anyone done an 1850?
Re: Fuel injection... on an 1850
#2 Post by Mad Mart »
Megasquirt if you're going EFi.
cliftyhanger
#3 Post by cliftyhanger »
down to budget.....
A weber inlet and set of jenveys would be nice....but not exactly a budget build.
The approach often used is to make a custom inlet with a single throttle body from modern car.
Or a set of individual throttle bodies (can be sourced off a bike)
however, none of the above is exactly a cheap exercise. However expect a healthy gain in mpg and power.
Cheapest solution is the check and fix the carbs, then book into a session on a rolling road. Can make a significant difference.
#4 Post by Jon Tilson »
I suspect if you show rich at lower revs you have worn jet holes.
This is quite common on SU'ed cars with the spring biased needle.
I suggest you invest in some new jets - common to Spit and dolly 1500.
Weak at the top is typical of an SU'ed 1850. BL did that on purpose hoping the road testers wouldnt notice.
Its why back in the day NBH would do 105 on bergs before I sprinted it. No SU'ed 1850 Ive ever had bar HOH was that
quick and HOH had clearly had work done.
Jeffers if you read this did you ever look at what needles are in HOH?
David....
#5 Post by sprint95m »
djw113uk wrote: but what about the inlet manifold - but has anyone done an 1850?
Fuel injected TR7s were sold in the USA.
A TR7 manifold will fit either type of 1850 head.
Jeroen has a fuel injected 1850 running on LPG but his is LHD....
the TR7 airbox won't clear the brake servo on a RHD 1850 apparently.
It may be worth a PM to him.....
Dolly-Nut
Re: David....
#6 Post by Dolly-Nut »
It also wont fit because of the bolt spacing between the HS4 & 6.
cliftyhanger
Re: David....
#7 Post by cliftyhanger »
Ah, but being fuel injection it wont have either carbs......
wiggybum
#8 Post by wiggybum »
I was only on about this the other day - maybe worth a guinea pig try on this system:
viewtopic.php?f=4&t=28295
I've found that a bad dizzy/vac advance will rob a lot of economy.
1981 1500 HL man/od
2007 MX5 Sport
2010 Citroen C1
1993 Gas Gas GT32
#9 Post by soe8m »
Koffieklets 4.jpg (133.01 KiB) Viewed 1667 times
djw113uk
#10 Post by djw113uk »
Was going to ask how and where that all came from, but just found your "new project" post. Looks great...going to take me a while to create & copy all that though!
David
#11 Post by soe8m »
Most of it was tr7. But a lot of bending and grinding to make it fit. I also had to make a spacer for the heaterblower as it is about 8cm further to the side. I used a tr7 ecu but it was running on petrol but not perfect. I just needed petrol injection to have my lpg injection running. It managed 13km on 1 liter lpg.
It going to on this now.
viewtopic.php?f=3&t=20105
jikovron
#12 Post by jikovron »
i once had the idea of using the efi system from a similarly sized engine in a late 90s car and applying it to a classic car engine..imo the running characteristics of a slant would be very similar to a renault 1.7sohc ,a vw 1.8sohc or a ford1.6 16v
with a custom crank trigger wheel fitted to the crank pulley and the injection parts and sensors adapted to the manifold most closed loop systems would adapt to the minimal fueling change automatically and give obd diagnostics /immobiliser to boot
i have heard about a 1.1 8valve ecu to be able to adapt to running a 1.6 in a citroen saxo after a few miles of lambda feedback
HTH
#13 Post by Carledo »
There is a Sprinted Toledo 2 door running around (changed hands a year or two ago) with what looked to me like XR3i injection on it.
djw113uk
#14 Post by djw113uk »
Yes, that is "flying farmer" I have seen that car - but missed out on buying it. It is ford kit, but he is far better at adapting systems to suit - just see his stag forum threads!
#15 Post by soe8m »
I can supply you a manifold. You have to make your own setup like plenum etc. There are some holes in it were the lpg injectors were in but you can put some plugs in.
