Spinning wheel nut
Ajay
Spinning wheel nut
#1 Post by Ajay »
One of my wheel studs has come away from the hub - the nut just spins. Need some clever ideas to try and get it off
Al
geeksteve
Re: Spinning wheel nut
#2 Post by geeksteve »
Front or rear? Either way it's going to be fun.. Do you have alloys or steel wheels?
Dolly-Nut
#3 Post by Dolly-Nut »
Remove the others and use a crowbar to leaver the wheel towards you very hard whilst undoing it, assistance would be useful. Alternatively clamp the nut with molegrips and wiggle and pull to try and re-spline it.
matt of the vivas
#4 Post by matt of the vivas »
Drill down into the nut from the front at the edge of the nut where it meets the thread on the stud. You need sharp cobalt-coated drills and lots of lube! When you have a fairly deep hole, hammer a tapered punch into the hole and hit hard - with luck the nut will split and pull off the stud. Done a few like this..... You will of course need a new stud and nut after but you shouldnt damage the wheel.
#5 Post by Jon Tilson »
What Matt said in theory but you could also use a dremel cutting disc to go down the side of the nutt.
