Hi,
Apologies for posting here but not had any luck in the Wanted section.
A couple of folk are on the lookout for one of these for me but no luck so far as any they may have are not readily to hand.
To clarify, the bit I need is the threaded piece that goes through the Camshaft Sprocket and the support bracket and onto which the slave nut fits to hold the sprocket in place on the bracket (and the timing chain under tension) when the head is removed. The person that assembled my Sprint's engine previously, managed to do it with out this
Does anyone have one that is surplus to requirements?
Many thanks,
Wanted: Spigot for Sprint Camshaft Sprocket
Tim Edwards
