various seals
various seals
Hi folks.where is the best place to get windscreen seals door seals etc.Myles
Re: various seals
I replaced the door seals on mine from Rimmers. Pretty good repro of the originals but lack the mitre in the corner, but with some careful cutting and gluing you can replicate that.
As for windscreen seals I suggest you use the search facility on this forum to see the various topic on it.
Re: various seals
They did do Myles but checking their website I can see the are no longer in stock.
Re: various seals
Hi Alan. I seem to remember quillers having quarter light seals in stock recently.Myles
Okay.....
The T2000 range use the same door seal profiles as our cars.
Chris Witor sells accurately remade seals of the these profiles. (These will need shortening for our cars.)
Chris also has 1/4 light seals but I believe Dolomite 1/4 light glass is smaller. However it may be possible
to cut down a 2000 seal?
