Gearbox tunnel
Gearbox tunnel
What is recommended as a sealant for the transmission tunnel. I don't want to use silicon as it will make future removal all the harder. Is it still possible to get the seemingly rubberised stuff of the original?
- SprintMWU773V
- TDC Staffs Area Organiser
Re: Gearbox tunnel
Silicone is usually very easy to remove. If you want hard to remove try butyl strip. I'd consider either using silicone or make up something suitable from some rubber.
Re: Gearbox tunnel
This stuff is very similar to what was originally fitted.
http://www.easycomposites.co.uk/product ... -tape.aspx
Re: Gearbox tunnel
That looks the ticket thanks very much have copied and pasted that to a question from dolowighty over the seal used on the boot floor where the fuel line comes through.Neil907 wrote:This stuff is very similar to what was originally fitted.
Thanks again
Re: Gearbox tunnel
Originally there is a rubber preformed gasket fitted to the tunnel.
