Gearbox tunnel
Posted: Sun Jan 25, 2015 12:18 pm
by Maidstonerob
What is recommended as a sealant for the transmission tunnel. I don't want to use silicon as it will make future removal all the harder. Is it still possible to get the seemingly rubberised stuff of the original?
Re: Gearbox tunnel
Posted: Sun Jan 25, 2015 7:18 pm
by SprintMWU773V
Silicone is usually very easy to remove. If you want hard to remove try butyl strip. I'd consider either using silicone or make up something suitable from some rubber.
Re: Gearbox tunnel
Posted: Mon Jan 26, 2015 12:53 pm
by Neil907
This stuff is very similar to what was originally fitted.
http://www.easycomposites.co.uk/product ... -tape.aspx
Re: Gearbox tunnel
Posted: Mon Jan 26, 2015 7:34 pm
by Maidstonerob
That looks the ticket thanks very much have copied and pasted that to a question from dolowighty over the seal used on the boot floor where the fuel line comes through.
Thanks again
Re: Gearbox tunnel
Posted: Tue Jan 27, 2015 8:38 am
by xvivalve
Originally there is a rubber preformed gasket fitted to the tunnel.
