Propshaft Delivery
Propshaft Delivery
#1 Post by Mad Mart »
I need to get a Sprint propshaft from Wokingham, Berkshire to Weston-super-Mare, North Somerset. Can anyone help?
thanks, Martin
wiggybum
Re: Propshaft Delivery
#2 Post by wiggybum »
I've used this a few times and it has worked out very good:
http://www.anyvan.com/
1981 1500 HL man/od
2007 MX5 Sport
2010 Citroen C1
1993 Gas Gas GT32
#3 Post by xvivalve »
How soon? If Tony is going to Triumph Show he can pass it to me, I can then get family to drop it off to you on their way past sometime...
#4 Post by xvivalve »
Using 'Interparcel economy' I can send up to four cill sections for pence over £14.00. A prop shaft is probably equivalent weight and slightly shorter. They pick up from and deliver to any address. You'd need to wrap it in cardboard.
For posting......
#5 Post by sprint95m »
You can split the propshaft and (cable) tie it to a length of sarking, then wrap it in polythene or cling film.
Karlos
#6 Post by Karlos »
I just used Interparcel - they subcontract to UPS, it was 15 quid for a pair of skis from Surrey to Wales - probably slightly less weight than a prop but much longer parcel.
tinweevil
#7 Post by tinweevil »
I can get it form Wokingham to the FOD any time but I won't be going down the M5 until August.
#8 Post by MIG Wielder »
I had a look round a couple of firms and under ....
https://www.myhermes.co.uk/help/carry-guide.html
I found good prices ,quick delivery ; but the big problem was " No vehicle parts" and if they are discovered they will dispose of them in transit.
Rather short sighted I thought as there are nice clean unused parts around as well as oily bits which I can see are a problem.
#9 Post by xvivalve »
If you opt for myHermes through interparcel.com your contract is with interparcel not myHermes; their restrictions are less restrictive. Most club panelwork goes through interparcel and I clearly put 'car panels' in the description.
http://www.interparcel.com/help/prohibi ... -items.php
