Help with identifying re-profiled cam
PaulB
#1 Post by PaulB »
Hi can anyone help me to identify a re-profiled Sprint camshaft?
All I can measure is the base circle diameter which is 1.09inch and across the cam lobe which is 1.445inch. Give a lift of 0.355inch which is pretty close to the strandard cam. Its definitely re-profiled, you can see the difference when you compare it with a standard.
Re: Help with identifying re-profiled cam
#2 Post by soe8m »
It can be a std spec regrind cam what was worn or damaged.
PaulB
#3 Post by PaulB »
I thinkl it is probably an uprated cam. The shape cam lobe is quite different to a standard cam,
trackerjack
#4 Post by trackerjack »
Has it got anything stamped on the end?
Holbay do mark but Newman dont, nor do they help with details.
#5 Post by Mad Mart »
Newman do stamp there cams Jon, or is that just the billet ones?
PaulB
#6 Post by PaulB »
It is stamped 59 on the end, but I don't know the significance if any.
#7 Post by soe8m »
The degrees to set? Do you have a picture of it?
PaulB
#8 Post by PaulB »
Here are two pictures of the re-profiled next to a standard camshaft.....
The re-profiled cam is on the left
trackerjack
#9 Post by trackerjack »
Mad Mart wrote:Newman do stamp there cams Jon, or is that just the billet ones?
Thats interesting Mart, perhaps the one I used was made in haste and it got left off, and they never did let me know what nominal setting was a good start so if my dodgy memory is right I set it at 109 deg.
A rolling road will sort it properly though.
PaulB
#10 Post by PaulB »
Anyone???
#11 Post by Jon Tilson »
IIRC STR91's and the TT equivalent are 106 ATDC inlet peak on no 1.
There is a chart on here somewhere....
TahitiSPRINT
#13 Post by TahitiSPRINT »
Hi Paul,
If the cam is of un-known origin and not marked, you have to measure the timing yourself with a dial test indicator (DTI) and with the cam mounted in a cylinder head.
You can test your measuring accuracy with the standard cam. The std cam should have a 18/58 – 58/18 timing (256 degrees duration).
With the newfound details on your re-profiled cam, you can compare with the list from the above link.
Have fun :)
Ronald
PaulB
#14 Post by PaulB »
Thanks guys,
I am familiar with the chart, but can't see how it helps me identify the camshaft???
#15 Post by soe8m »
Set the valve play as narrow as possible, about 0,05mm. Note the degrees in turning when the inlet valve starts opening and is closed. That is the duration. The lift you can calculate by the cam hight minus the base circle. The found figures you can compare with the tabel and then you know what cam you have.
