Restoration of LRM (VA930)
GazMaz
#1 Post by GazMaz »
045_opt (1).jpg (32.3 KiB) Viewed 4893 times
The restoration on LRM (VA930) is slow but steady.
Have completely removed the sun roof which I think is beyond repair.
Would not like to go along the road of replacing the roof so will need another sun roof to fill the 99cm by 83cm gap.
Can anyone suggest a half decent sun roof without me having to take out a second mortgage!!!
Cheers!
Looks like I am going to need some new headlamp retainers
Feb 2015 008_opt.jpg (90.07 KiB) Viewed 4893 times
Bonnet back to bare metal. Only took me three days!!
Feb 2015 007_opt.jpg (90.08 KiB) Viewed 4893 times
Re: Restoration of LRM (VA930)
#2 Post by soe8m »
Well, there is another way what i did at my wife's 2500. It had a big rotten sunroof also. I did cut out a roofskin from another 2500 and glued it over the existing with body glue. Then added a vinyl roof and it's invisible.
grifterkid
#3 Post by grifterkid »
That looks very good indeed sir...
What kind of sunroof was fitted before?! Maybe you can fit a Webasto or similar to fill the gap and keep it looking original for the period?
Failing that I am sure a new (or good S/H) roof skin can be cut to fit the gap or a whole nes section can be fitted.
Whatever you chose to do I am sure it'll end up looking pretty much perfect!
Please do keep us posted... :wink:
GazMaz
#4 Post by GazMaz »
grifterkid wrote:That looks very good indeed sir...
Don't know the type of sun roof that was fitted. Can't find anything on the sunroof that would identify who made it. If I knew I would probably just replace it.
GazMaz
#5 Post by GazMaz »
soe8m wrote:Well, there is another way what i did at my wife's 2500. It had a big rotten sunroof also. I did cut out a roofskin from another 2500 and glued it over the existing with body glue. Then added a vinyl roof and it's invisible.
Jeroen,
This sounds a good idea but is it that easy? There are stiffeners in the sunroof, did you use any stiffeners when you glued the roofskin?
#6 Post by soe8m »
It needs two man. You cut out the remains of the old sunroof and lower the other roofskin on top of the car. I did some tackwelds at the edges and a bit of filler to smoothen. It was done in one evening. You only have to buy an headlining and the frames because that will be cut in yours because of the sunroof.
GlenM
#7 Post by GlenM »
It might well have been a Webasto. There was a brand new one for a Dolomite on E-bay a few days ago, it had been in the sellers loft since 1979.
#8 Post by xvivalve »
Original equipment below, Club repro galvanised above. £38 each delivered
GazMaz
#9 Post by GazMaz »
This is the offending sunroof. I know it's a long shot but does anyone have any idea the make of sunroof it is?
Feb 2015 010_opt.jpg (89.96 KiB) Viewed 4737 times
grifterkid
#10 Post by grifterkid »
Blimey...!
That looks like a Britax 'cartridge' style sunroof where the hole was cut in the roof then that unit, or 'cartridge', was inserted that had the sliding portion within it...
It'd be quite a cool period accessory to keep but I imagine you want to take your car back to original spec'...?!
I am sure you'll be able to sell that on to someone somewhere... :wink:
GazMaz
#11 Post by GazMaz »
grifterkid wrote:Blimey...!
Grifterkid,
You are spot on there, it is a cartridge! Big hole in the roof and the cartridge riveted to the roof. The sliding part of the roof is still in quite good condition. Could try to restore it and put it back on if I could find a replacement draught excluder which has totally rusted and fell to pieces. I took it off to so I can fit a new vinyl roof. Still not sure which way to go here, restore sunroof or new roof. Will bear in mind who has first dibs on it. If I do get rid there will be no charge and it is yours, apart from the courier fee!!
Pippin
#12 Post by Pippin »
While we're on the subject of sunroofs, were Webasto the only ones that were fitted from new? My Dolly has what I believe to be an after-market glass tilt sunroof (I forget the make) and I'm considering removing this and returning the roof to original when I eventually get round to restoring the rest of the car.
Jer
grifterkid
#13 Post by grifterkid »
GazMaz wrote:If I do get rid there will be no charge and it is yours, apart from the courier fee!!
Well that is really very kind of you indeed...
If the car were mine I'd go back to having a 'solid' roof as although a sunroof is good to have they can cause a myriad of problems... Having said that though there are many cars that have sunroofs fitted that have not had problems so it is all down to luck and thorough maintenance with regards to how any old car is today...
Give it some thought and I'm sure you'll come up with the right answer... :wink:
#14 Post by Jon Tilson »
Britax weathershield was a common dealer fit and is webasto style....by which I mean folding vynil with a pop
up green visor at the front edge.
I just scored some roof bars for one of these. I just missed out or got sniped for the two recently on ebay.
Been after one for a while.
Now I've scored the frame I'll be after the folding bit, which I think is still made by some specialists.
#15 Post by xvivalve »
I have a complete second hand roof in good order sitting under my carport in the yard, it was about the only panel worth keeping off that particular car. It is cut partway down each pillar.
It is cumbersome and I'm in the mood to make space, so make me an offer and take it away...
