Am I right in thinking the bolts for the front brake discs have the same pcd as the wheel stud pcd ie 95.5mm ? Working out my plan for the trackerjack conversion.
PCD question re- brake discs
Re: PCD question re- brake discs
I reckon the pcd on the brake disc bolts is 85 to 86 mm. So a bit smaller. Its quite difficult to get my callipers in to measure this so its a bit of an estimate I'm afraid. Longer jaws needed.
HTH,
HTH,
ok thanks Tony for looking. I'll have to strip mine down and measure it. was hoping to get a bit done before I need to pull mine apart
- trackerjack
Close enough mr Mig
I measured accurately a disc today and the fixing holes for disc are 3/8 UNC on a 3.407" (86.54mm) PCD.
