pre.installation engine test.
Dollyby 2
#1 Post by Dollyby 2 »
Hi all.I want to test the engine of 1500dolly. before
I install it.how do I get around the coil aspect.thanks. Myles.
Re: pre.installation engine test.
#2 Post by Jon Tilson »
The engine needs proper support at the sides and the back.
You just need a common earth point and a battery and fuel
supply and a wired up ignition circuit and starter switch....
All this is quite conveniently on hand if you put it in a car...:-)
SprintMWU773V
TDC Staffs Area Organiser
#3 Post by SprintMWU773V »
Best thing to do is give it a good inspection with the head off and sump off. If everything is OK here then it should run fine. The idea of bolting it to a workmate and getting it going whilst amusing would be rather unwise and unsafe. Unless you have a dyno I'd leave it to the pros.
Dollyby 2
#4 Post by Dollyby 2 »
Hi again.Jon,Mark, I have taken your comments on board and decided to just go ahead and install the engine and box as a unit.Thanks for your comments. Myle's.
Jod Clark
#5 Post by Jod Clark »
I made this when I used to do Triumph engines a lot. It also doubled as a transport cradle and left me when I did my final Triumph engine a few years ago. It worked well, though the electrics were a bit rough and ready
Dollyby 2
#6 Post by Dollyby 2 »
That looks really a handy piece of kit Jod.I've just bolted the unit in today.now to fit gear box mount.
driveshaft etc.etc.Myles.
trackerjack
#7 Post by trackerjack »
This is my rig and a recent test carried out :D
https://www.youtube.com/watch?v=a8ooK584XBA
geeksteve
#8 Post by geeksteve »
I'm assuming just leaving it mounted in a subframe would be ok?.. Can't imagine it going far.
