A little while ago I replaced a tube on top of the engine that was leaking coolant, however now I think I've got a possible leaking bypass tube by the thermostat housing? Coolant keeps gathering in the little groove between the engine block and the housing, and running down beneath the inlet manifold down the side of the engine.
Apparently that the way to fix this involves taking the inlet manifold off but I can't find gaskets outside Rimmers anywhere, but I've heard their gaskets are pretty poor?! Fitchett don't seem to have any, any other recommendations?
Also, as I'm on the subject, my temp gauge usually sits about 2/3 the way up, and on hills can climb right up almost to 3/4? Planning on flushing the system through when I try fix the leak, but is that normal? My last car never went over about 1/4!
Thanks guys
