Hi have a trailer which is 10ft by 5ft as was wondering if a sprint would fit on this? they say the dimension are as follows:
mm inches
wheelbase 2454 96.6
track/tread (front) 1356 53.4
track/tread (rear) 1290 50.8
length 4115 162
width 1568 61.7
height 1372 54
ground clearance
length:wheelbase ratio 1.68
kerb weight 1015 kg 2238 lb
the width is that overall width including any mirrors etc or would that outer tyre to outer tyre, as this just over 5ft?
many thanks Gary
dimensions of a sprint?
Re: dimensions of a sprint?
If it will fit, it will be tight. My trailer is 1640 mm bed width which is just shy of 5'5". There is probably a couple of inches either side when loaded with a Sprint. Length wise your wheel base will fit into 10', but you need to accommodate an small overhang to the front and a larger one to the rear.
