1300 fwd or toledo rear bumper are they the same
northdave
#1 Post by northdave »
HI, does anyone know if a Toledo rear bumper bar fits a Triumph 1300 FWD. I know I will need a hole put in for the center badge but do the corners fit and do the brackets line up. I know the part numbers are different.
Nathan Mwk 627G
Re: 1300 fwd or toledo rear bumper are they the same
#2 Post by Nathan Mwk 627G »
I've just fitted a short Toledo bumper to my 1300 and the original 1300fwd bumper irons don't perfectly line up. I can't see why a full rear Toledo bumper wouldn't fit as it's the same body shell from the bulkhead back so the sides should line up.
If needs be fit the Toledo rear irons and all should be ok, you will need to take the tank out to gain access to the rear of the irons and the side bolt as it's all done from inside the boot.
