Fuel hose sizes?
Fuel hose sizes?
#1 Post by tony g »
On my sprint I want to change all the rubber fuel pipe to R9 spec. Does anyone know what the sizes are? From the tank line to the steel pipe and then to the fuel pump inlet. Exit from the the pump to the "rail" then from the rail to the carbs. The R9 is expensive and I only want to get the minimum I need :)
Flyfisherman
Re: Fuel hose sizes?
#2 Post by Flyfisherman »
See attached: viewtopic.php?f=4&t=21507
Paul
#3 Post by tony g »
Cheers Paul :thumbsup:
