shock mounts stripped bolt
andrew_27
#1 Post by andrew_27 »
sadly i've just discovered one of the shock absorber top mount studs on my Toledo suspension (front) is stripped, im hoping i can re tap it with a suitable die but if not does anyone have any advice...i.e. can you fit new studs?? as the whole part assembly (142777) is unavailable everywhere ive looked.
Aye...
#2 Post by sprint95m »
It is possible to replace the bolt Andrew.
To do this it is necessary to remove the shocker assembly from your car and then compress the spring to allow the top plate to be removed.
Once the top plate has been removed it is a case of grinding off the old bolt before welding in a replacement.....
Re: shock mounts stripped bolt
#3 Post by Carledo »
Pretty sure I have a spare front tolly shock topmount about somewhere if you're stuck!
andrew_27
#4 Post by andrew_27 »
problem averted, managed to get the threads re cut and the nut tightens down nicely, thanks for the help though!
Aye...
#5 Post by sprint95m »
That is good news.
