shock mounts stripped bolt
Posted: Sun Jun 14, 2015 8:53 pm
by andrew_27
sadly i've just discovered one of the shock absorber top mount studs on my Toledo suspension (front) is stripped, im hoping i can re tap it with a suitable die but if not does anyone have any advice...i.e. can you fit new studs?? as the whole part assembly (142777) is unavailable everywhere ive looked.
Aye...
Posted: Sun Jun 14, 2015 9:15 pm
by sprint95m
It is possible to replace the bolt Andrew.
To do this it is necessary to remove the shocker assembly from your car and then compress the spring to allow the top plate to be removed.
Once the top plate has been removed it is a case of grinding off the old bolt before welding in a replacement.....
Re: shock mounts stripped bolt
Posted: Mon Jun 15, 2015 9:13 am
Pretty sure I have a spare front tolly shock topmount about somewhere if you're stuck!
Posted: Mon Jun 15, 2015 11:42 am
by andrew_27
problem averted, managed to get the threads re cut and the nut tightens down nicely, thanks for the help though!
Aye...
Posted: Mon Jun 15, 2015 2:36 pm
by sprint95m
That is good news.
