Tickover or Rev
Posted: Mon Jul 06, 2015 5:17 pm
by AlanH
I have found that if I get my 1850 ticking over OK it will not rev much past 3000. It dies and then picks up again.
However if I set it rich at tickover then it it revs OK.
I have changed the jets, needles and float bowl valves but it still does it.
Re: Tickover or Rev
Posted: Mon Jul 06, 2015 8:31 pm
by SprintMWU773V
Your mixture is obviously wrong and/or you have an air leak somewhere.
Re: Tickover or Rev
Posted: Tue Jul 07, 2015 10:04 am
by Jon Tilson
Have a read of this....
https://dollywiki.co.uk/wiki/SU_Carburetor_Tuning
SU'ed 1850s are mostly weak at the top end....most will struggle to pull 90 in top or o/d.
If its flat at 3500-4000 rpm try pulling the choke. If it picks up you need a richer needle.
The minty lamb web site has an SU needle chart wher you can compare profiles.
Mine is now on HS6's and a TR7 engine and will keep going at over a ton...
Re: Tickover or Rev - culprit(s) found
Posted: Tue Jul 07, 2015 3:46 pm
by AlanH
Turned out the main culprit was a bent filter (see below). I am getting a metal one.
However when I was setting the carbs up again, one of them would not lean out , that turned out to be a blocked vent in the float bowl.
http://sucarb.co.uk/technical-carburett ... s-flooding
In fact there was still a bit of casting in there.
Working much better now but it may be worth looking at different needles. They are AAQs at the moment, anybody got any suggestions.
Re: Tickover or Rev
Posted: Tue Jul 07, 2015 6:07 pm
by Toledo Man
The factory workshop manual says ABK needles. I can't really add any more to what Jonners has suggested. What are your carb mounts like? My next job on mine (when I finally get the car back) will be to fit solid carb mounts.
Re: Tickover or Rev
Posted: Tue Jul 07, 2015 9:18 pm
by AlanH
I managed to get a pair of solid ones from Ebay. I won't tell you how much I paid for them because I don't want to spoil your day !.
Also, I have been playing and it's now much much better. I think that I may have got the needle type wrong, I will have a look.
Re: Tickover or Rev
Posted: Wed Jul 08, 2015 8:44 am
by Jon Tilson
AAQ is the "recommended" rich needle for a 1500 spit.
Look at ABK first on the minty chart and go slightly richer at the top for that.
Make sure the ignition advance is working too.
Re: Tickover or Rev
Posted: Wed Jul 08, 2015 9:22 am
by Edin Dundee
Jon Tilson wrote:AAQ is the "recommended" rich needle for a 1500 spit.
I've just had a look and AAQ or AAT are the richer alternatives to ABK. I'm assuming the first time you visit the site it gives the default alternatives?
http://www.mintylamb.co.uk/suneedle/
Re: Tickover or Rev
Posted: Wed Jul 08, 2015 11:53 am
by AlanH
As usual I got it round my neck.
The dolomite needles are ABK and the AAQs are on my Herald.
AAQs do look like a good richer alternative to ABKs and I think that I may have a pair somewhere so I may give them a try.
