Radiator mounting set screws / bolts ?
DavePoth
#1 Post by DavePoth »
The ones that connect the radiator to the bracket. Any ideas on a size for them? I think they're 1/4" UNF but I'm unsure on the length since I've now lost them. :oops:
Re: Radiator mounting set screws / bolts ?
#2 Post by Jon Tilson »
They are sort of special with a spiral cut down the threads to ease removal in rust and not bind on the captive nuts.
Try Ficthetts....
#3 Post by MIG Wielder »
They also have a pointy end to help location in the captive nuts.
Try 519040 for a 1500, SH605081 for an 1850 and HU807D for the Sprint. The Sprint also has spring washers.
#4 Post by Jon Tilson »
Ha...fancy the Sprint and 1850 having different p/n's for the same thing.
Only the rad core is a bit beefier on a Sprint. The bracketry is the same...
SprintMWU773V
TDC Staffs Area Organiser
#5 Post by SprintMWU773V »
The design of the bolts is primarily designed to aid assembly when the captive nuts are full of paint on the line. When restoring you have more time to tap out the threads and normal bolts can be used.
Okay.....
#6 Post by sprint95m »
The question is about the bolts that hold the radiator within its brackets.
These are 1/4" UNF set screws.
When I needed these previously, I got the shortest I could find then cut them down to a suitable length.
As they are flared, the heads on OE set screws have a smaller socket size than the usual, but the normal head type in conjunction with spring washers work fine.
#7 Post by MIG Wielder »
Ah yes ! Sorry about that. :oops:
I was always told at school to read the question properly before answering.
DavePoth
Re: Okay.....
#8 Post by DavePoth »
sprint95m wrote:The question is about the bolts that hold the radiator within its brackets.
Cheers for that. I guess they need to be about half an inch long or so when cut down?
AlanH
#9 Post by AlanH »
I used these with a spring and flat washer (and a bit of copper grease).
http://www.ebay.co.uk/itm/Stainless-Ste ... 53ecacf268
