Buying a Dolomite
Coastline
Buying a Dolomite
#1 Post by Coastline »
Thanks for all the advice guys. :D I am happy with all that now.
Edin Dundee
Re: Buying a Dolomite
#2 Post by Edin Dundee »
Definitely with overdrive if possible, it makes a huge difference to the engine revs and noise.
The gearboxes on 1850s are weak.
I'll stick my neck out and say 1850s are more liable to 'engine problems' than Sprints due to the possibility of the head not wanting to come off.
The two share the same water pump design, distributor drive design...
The Sprint gearbox is infinitely more robust than the 1850.
Coastline
#3 Post by Coastline »
Many thanks for the advice, much appreciated. Finding one that is not a project car is going to be my next challenge. Thanks again.
#4 Post by Toledo Man »
Have you considered an auto. No clutch or gearbox problems to worry about and the engines have an easier life.
Coastline
#5 Post by Coastline »
Yes, I would consider an auto, great idea. Thanks.
Dolly-Dimple
#6 Post by Dolly-Dimple »
All the best in your search, keep us posted :-) Great bunch of friendly people here with plenty of help on hand. Kind Regards Russell
#7 Post by Jon Tilson »
Just seen this...
Overdrive IS desirable but there are other considerations, like carting it round all the time if you just do town or
country B road work. The gearbox mounting is crap to be frank, and every dolomite 1850 Ive ever had with overdrive never felt so "tight" mechanically as one without because of it.
Depends on how/where you drive it.
Keep an eye on the coolant level, change the oil and you should see 80k miles between major requirements like
timing chain replacement and water pump seals weeping, both of which normally give you some warning.
They are the business. Love them to bits and buy the first good one you see regardless of transmission. Autos
are also brilliant...
Coastline
#8 Post by Coastline »
:D Thanks for all the advice guys, appreciated but have to put the project on the back burner as something has cropped up making it impossible to buy at the moment.
