running on unleaded
ragtop
running on unleaded
#1 Post by ragtop »
Hi, Has any one used or could recommend one of these, Any thoughts on these.
http://www.ebay.co.uk/itm/350256406085? ... EBIDX%3AIT
1972 Triumph Toledo PKS 379L Emerald green
1974 Triumph Stag
1993 Vauxhall Corsa Died now growing flowers in it
11 Vintage Tractors
2007 Isuzu Rodeo
Re: running on unleaded
#2 Post by Carledo »
Total waste of money! If you have an OHV Dolly/Tolly like your avatar and the head has not been off then the valve seats will have a limited "lead memory" which will help to marginalise valve seat recession unless you thrash it mercilessly. In the meantime save up a couple of hundred quid and get the head converted for unleaded ONLY when it starts to fail, which could be next week or 10 years hence!
But these lead replacement doohickies are a trap for the gullible!
LewBLew
#3 Post by LewBLew »
Carledo wrote:Total waste of money! If you have an OHV Dolly/Tolly like your avatar and the head has not been off then the valve seats will have a limited "lead memory" which will help to marginalise valve seat recession unless you thrash it mercilessly. In the meantime save up a couple of hundred quid and get the head converted for unleaded ONLY when it starts to fail, which could be next week or 10 years hence!
How can you tell when it starts to fail because of the lack of lead?
Triumph1300
#4 Post by Triumph1300 »
When your valve clearances start to dramatically close up.
Hasn't happened yet on KAC despite 15 years, and 50 k miles of abuse, towing, tracks etc
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
mahony
#5 Post by mahony »
You could always try this ( treats 250 litres )
http://www.halfords.com/motoring/engine ... stabiliser
trackerjack
#6 Post by trackerjack »
Just been reading an old classic car mag from 2003 and in it was a TR7 and the recommended action was to spend £275 (with a famous Triumph parts supplier) on an unleaded head :shock: :roll: :evil:
I ran my Sprint on pump petrol for years including thrashing it and valve problems were not an issue.
Yes I know the iron engines are not so unleaded friendly.
#7 Post by Toledo Man »
Steve is bang on the money. Just run it on unleaded and save up for a rebuild for when the time comes.
