improving refinement
cleverusername
#1 Post by cleverusername »
Something my father complains about in the old 1500HL. Now I will have to strip out the dash to get to the stuck heat vent control, so I thought maybe add a bit of sound deadening to make it a little less deafening at seed.
Now as for as I understand I need material with some mass to it to achieve this. Has anyone got some recommendations?
cliftyhanger
Re: improving refinement
#2 Post by cliftyhanger »
Dynamat is very good, but not cheap.
If you want cheap, I have used heavy rubber waffle carpet underlay, works very well. Not easy to stick to vertical surfaces though, and can hold water.
Sealing ALL holes/gaps in the bulkhead makes a surprising difference too.
SprintMWU773V
TDC Staffs Area Organiser
#3 Post by SprintMWU773V »
I used Dodo Pro. It's easy to cut and heavy so good for noise dampening.
