Worn carb parts
AlanH
Worn carb parts
#1 Post by AlanH »
I took my car to have the engine looked at by Geoff Bloor in Nottingham.
He managed to set it up quite well but one of the things that he came up with was that there was play in the throttle spindles.
We got talking and he said that this wear was greater due to the lack of lead in petrol.
This got me thinking, we get our heads modified, if needed, to take unleaded but what about elsewhere? Should we use lead replacement anyway?
I'm going to replace the spindles (I hope that I don't need to do the bushes) and I wonder if it would be worth putting some thin grease on them.
mahony
Re: Worn carb parts
#2 Post by mahony »
Must admit i have never heard unleaded petrol causing throttle spindle wear before :o
cliftyhanger
Re: Worn carb parts
#3 Post by cliftyhanger »
That don't make sense to me. There is no petrol flowing through the spindle/body.
New spindles usually help a great deal. If the bodies are that worn it is easier to buy a decent set rather than try to get yours rebushed. Grease will get sucked out at some stage, but won't hurt.
Re: Worn carb parts
#4 Post by Jon Tilson »
Early carbs with sideways pulling return springs last about 40k miles before wear makes idel adjustment difficult.
The later type with concentric springs last well over 100k.
AlanH
Re: Worn carb parts
#5 Post by AlanH »
I've got the spindles, is it worth soldering up the overrun valves?
cliftyhanger
Re: Worn carb parts
#6 Post by cliftyhanger »
Yes. And then chop the back bits off them too.
Re: Worn carb parts
#7 Post by Jon Tilson »
Or just buy plain discs and knife edge them.
Richard the old one
Re: Worn carb parts
#8 Post by Richard the old one »
When I top up my carb dampers I normally drip some oil down on the carb spindles in the hope that this will help to lubricant the spindles and so reduce the wear. It can't do any harm so its worth doing.
AlanH
Re: Worn carb parts
#9 Post by AlanH »
Good idea !
AlanH
Re: Worn carb parts
#10 Post by AlanH »
What is Knife edging Jon?
Re: Worn carb parts
#11 Post by Jon Tilson »
Filing the edge of the discs to a thin edge like a knife blade.
Dollyby 2
Re: Worn carb parts
#12 Post by Dollyby 2 »
Hi folks,I don't wish to appear to hijack this
thread but I to have problems with worn spindles,bushes and carbs in general on my 1500 hl.Should one be able to stall the engine by turning up the the two nuts on the jet's to the last, I did this and it still seems to be running rich and is rough on idle, about 800 revs,is the wear in spindles/bushes responsible for this,regards to all, Myles.
Re: Worn carb parts
#13 Post by Jon Tilson »
Check your float valves. Overflowing chambers is the biggest cause of rich running.
After that look at collapsed waxtstat pellets if you have waxstats.
Also check the choke linkage isnt causing the jet to stay down. Alos very common.
Try pushing up on the bottom of the jet. If it moves up the choke linkage is sticking.
Dollyby 2
Re: Worn carb parts
#14 Post by Dollyby 2 »
Hi Jonners,my carbs are non waxstat,the number on both floats is Fzx1258f, what does this denote to?.I am not very familiar with su's,the choke is disconnected and both sets of clamps are loose also,there is some play in the spindles.I will check float levels when I get a minute or three,I presume this means taking the lid off and a visual.Would centering the jet/needle help? thanks so much for your help.Regards, Myles.
AlanH
Re: Worn carb parts
#15 Post by AlanH »
Check the breather/overflow outlet on the top of the float bowls, if that is blocked the pressure will cause rich running.
