You wiggle the gear stick!
not aggressively just a little wiggle to check you're in neutral and it's all fine. no problems when driving (apart from 1500TC big ends on their way out).
could there be a problem with the reverse switch? no overdrive or shorts. no battery drain. no funny burnt smells.
Any ideas as I'm stumped?
