Sprint clutch master cylinder required....
shaunroche
#1 Post by shaunroche »
As the above as mine it turns out is knackered and the club has none.
Can anyone tell me where to get a new one from or someone to refurbish my old one please?
Yes.......
#2 Post by sprint95m »
Any of the kit car suppliers can supply these brand new,
you will need an adapter too because the outlet in these is 3/8"UNF, whereas the clutch is 7/16" UNF
and a clevis fork (or use your own push rod if it is still okay).
Car Builder Solutions give a generous discount to TDC members. It is worth getting their (free) catalogue....
http://www.carbuildersolutions.com/uk/0 ... -reservoir
http://www.carbuildersolutions.com/uk/b ... unf-female
http://www.carbuildersolutions.com/uk/i ... 8-unf-male
http://www.carbuildersolutions.com/uk/s ... levis+fork
Mahesh
Re: Sprint clutch master cylinder required....
#3 Post by Mahesh »
shaunroche
#4 Post by shaunroche »
Thanks Ian, that's very comprehensive!
Mahesh, has yours got that built in reservoir on it?
I'm thinking of rebuilding mine as I've got a sprintspeed clutch kit fitted......if I get a Rimmer's refurb kit, how difficult is it to take it apart?
#5 Post by Carledo »
Once it's off, the master cylinder is a piece of cake to refurbish, half an hour if you dawdle!
shaunroche
#6 Post by shaunroche »
Carledo wrote:Once it's off, the master cylinder is a piece of cake to refurbish, half an hour if you dawdle!
You don't work for Haynes manuals do you? ;)
#7 Post by xvivalve »
It took you, me, Jonners, Mad Mart and a few others longer than that at the NEC a couple of years ago!!
#8 Post by Carledo »
Not me mate, the one I had dealings with at the NEC was your vermillion AUTO!
The only thing that can make the job longer is if the piston is seized in the cylinder from years of standing - which I don't think applies to Shaun's car.
shaunroche
#9 Post by shaunroche »
So being predictable and very boring....how do I go about getting it apart etc.?
Said I'd be boring.....
#10 Post by Jon Tilson »
Just take out the circlip and give it a shake if its been in recent use.
If not and the piston is seized in the bore, then a bit of air pressure from a tyre pump usually has them out if they move at all...
Worst case is you give up after a month of soaking in bilt hamber deox. I have a few like that....but they were pretty obviously a waste of time.
If the piston moves it will come out....
The NEC incident Alun is refering too was a duff recuperating seal in the first kit IIRC....we sorted it in the end.
shaunroche
#11 Post by shaunroche »
Brill, cheers Jonners......it does move but I wasn't sure if I had to blow it out or use pressure....will order a kit now.
Cheers once again!
