Wiper wheel box bush?
shaunroche
#1 Post by shaunroche »
I'm after the two rubber grommets that go onto the wiper spindles....
Is this really what I want as they seem very expensive!! Any alternative suppliers?
http://www.rimmerbros.co.uk/Item--i-519323
viewtopic.php?f=10&t=14205
Re: Wiper wheel box bush?
#2 Post by Carledo »
If what you want is the seal that goes between the nut and the bulkhead then that is the correct part number according to my Sprint parts list
But that price is daylight robbery! Try ringing Fitchetts!
shaunroche
#3 Post by shaunroche »
It is Steve, cheers...I'm sure I've seen it cheaper elsewhere but i just can't remember where!
Mahesh
#4 Post by Mahesh »
Might be worth ringing Mick Dolphin,
Why not.......
#5 Post by sprint95m »
Make your own out of nylon 66....?
shaunroche
#6 Post by shaunroche »
I couldn't get them made for 7 quid each I don't think Ian!
80Sprint
#7 Post by 80Sprint »
Depends how original you want it. Try rubber washer suppliers on the web, you should find something similar. I am just pulling mine apart as well but think mine may be ok to re-use.
