I believe that there are difference between early and late Sprint cylinder blocks. Can anyone outline what the differences are?
Thanks.
- GrahamFountain
Re: Sprint cylinder blocks
According to a mate of mine, who really ought to know, early sprint blocks have a bit more chrome in the alloy they are cast from. But later castings are the same for both Doly and TR7. Don't know when the change was.PaulB wrote:I believe that there are difference between early and late Sprint cylinder blocks. Can anyone outline what the differences are?
Cylinder blocks Graham, not heads.
- GrahamFountain
No, I do mean the blocks. Cast iron is an alloy of iron and, mostly, carbon and sillicon. "Chromium is added in small amounts to the ladle to reduce free graphite, produce chill, and because it is a powerful carbide stabilizer" https://en.wikipedia.org/wiki/Cast_ironMad Mart wrote:Cylinder blocks Graham, not heads.
Was going to come to your defence there but see you've done it yourself....
Bit of Molybdenum goes in too IIRC.
Early ones also have cross drilled cranks - but you all knew that.
- GrahamFountain
Next time I talk to Nick, I'll see if he has more details on the alloyants, or a soure for the info.Jon Tilson wrote:Bit of Molybdenum goes in too IIRC.
Graham.
Later blocks sprint,tr7 or 1850. Have bigger waterways around the pump and pos slightly bigger oil ways. The best block to use is a late but used 1850 block bored out to 2ltr.
