brake master cylinder tandem
kc1954
#1 Post by kc1954 »
hi can anybody help with a couple of questions that I have the first one is how do I remove the second piston in the cylinder I don't know if it has seized there is slight rust around it, the first bore is fine also how does the resevour detach there are no pins or screws indicating how it is fixed, I believe it is from a 1980, 1850 dolomite thanks kevin
Re: brake master cylinder tandem
#2 Post by Mad Mart »
From memory there is a pin stopping the second piston from coming out. You can se it when you remove the plastic reservoir. The reservoir is detached simply by pulling it out of the rubber grommets.
