Fitting Sprint tailpipe
simonhorton
#1 Post by simonhorton »
Hi all,
Please can you explain how the rear tailpipe is put into place
I know I have to remove the l/ h rear wheel , but is there anything else that needs removing ?
Many thanks for your help
Re: Fitting Sprint tailpipe
#2 Post by tony g »
It should go in but the body needs jacking from the body not the axle, and the pipe fed in from the wheel arch. A bit fiddley but doable. Good luck :)
simonhorton
#3 Post by simonhorton »
Do I need to undo the tie bar or the suspension ?
Thanks :?
simonhorton
#4 Post by simonhorton »
Hi Mike,
Many thanks for the info on fitting the rear silencer
I'll be Uri Gellor by the time it's fitted
Kind regards
Simon :D
#5 Post by Jon Tilson »
I dropped my angled tie bar and the radius arm. The trick to save this would be to do it on a 4 post lift, then you can get the pipe down enough and corkscrew it in.
You do get the knack after practice...
James467
TDC Sprint Registrar
#6 Post by James467 »
Does this help?
simonhorton
#7 Post by simonhorton »
Many thanks James
I have that book somewhere
Regards Simon
#8 Post by Toledo Man »
The parts catalogues & factory workshop manuals are available for download from my BT Cloud.
Karlos
#9 Post by Karlos »
"Carefully manoeuovre the tailpipe assembly through the wheel arch" - sums it up!
