Cleaning stained headlining , any ideas ??
Hello All,
I want to clean up my headlining as it is stained by the doors ( brown water marks etc )
Any suggestions what to use please
Many thanks
Many thanks
Re: Cleaning stained headlining , any ideas ??
Apparently if you paint it with vinyl silk emulsion, same stuff as you would use in the house, it comes up like new.
I've done this on mine. Take a look at my "resto" thread. Any vinyl silk emulsion will do. You will need at least 2 coats.
The brown marks are usually from the original factory adhesive. They were like it from new! As the previous poster suggests, vinyl silk emulsion paint is the way to go.
1980 Dolomite 1850HL Auto
1977 Dolomite 1500
1977 Dolomite 1500
The vinyl silk idea seems superb but has anyone had any experience of it peeling off at all...?!
Personally I'd try and clean the headlining first with a stiff nail brush and a solution of warm water and 'Stardrops' multi-purpose cleaner.
Make sure you cover the seats and other surfaces first though just in case!
Hi
Thanks for the information , I'll try that way as well
Thank you
Thank you
- Flyfisherman
Hi Paul,
The headlining looks great
What sort of paint and felt pad did you use ?
Simon
Simon
- Flyfisherman
Simonsimonhorton wrote:Hi Paul,
Simon
Emulsion paint - same paint the you paint the ceiling or non wall papered walls.
Felt pad - http://www.ebay.co.uk/itm/Harris-Taskma ... 1239673420
Paul
Hi Paul,
Many thanks mate
Simon
Many thanks mate
Simon
