Tracing a leak
Posted: Mon Feb 01, 2016 2:24 pm
Afternoon
I'm becoming mildly frustrated by the puddle of water that keeps appearing in my 1300's passenger footwell. I thought I'd solved the problem when I found a small hole in the scuttle, just behind the bulkhead, but having taken care of it the water is still getting in.
The windscreen rubber seems fine, and I can't see any other ingress points in the bulkhead. There seems to be a slight trace of moisture coming down the inside of the bulkhead, but I can't see the source (not without ripping out the dash, anyway).
Are there any other obvious areas I should be checking before I just drill a drain-hole in the floor?
