Guy's
Always been a ball of contention as per the above subject - "Which is best" to do on a modern / classic.
I ask the question because my Merc Vito goes to Enza at Warrington for servicing - I have to drive to Warrington so the engine oil is hot, so drain oil whilst hot or leave it till it goes cold - engine oil change is the last service activity to do.
Also my Octy Vrs is going for a service this Frday - I have to travel to Congleton (about 20 miles for me) as I go to an independant VAG garage, once again the oil will be hot, so drain oil whilst hot or leave it till it goes cold.
Paul
Hot Oil Change or Cold Oil Change
- Flyfisherman
Re: Hot Oil Change or Cold Oil Change
I always change oil when hot, runs more and brings more of the crud out with it. Hurts more if you get it up your sleeve though.
Whenever possible, I change oil when its hot, even if I have to warm the engine first! It was one of the first things I was taught as a spotty 16 year old apprentice, 40+ years on and many thousands of oil changes later, I still do it the same way.
I'm with both Steves on this one but I give it a few minutes for the oil to cool down a bit so you don't scald yourself when you undo the drain plug.
- SprintMWU773V
- TDC Staffs Area Organiser
I tend to go warm rather than hot. I did the Mazda at the weekend, took it for about a mile run, came back. Nice and warm but not so hot that it scalds you. This approach has always served me well. Even if changing the lawnmower oil I let it run for a bit to warm it, then drain.
You should always drain oil when its hot. As mentioned, it flows easier, more completely and in less time, than when cold.geeksteve wrote:I always change oil when hot, runs more and brings more of the crud out with it. Hurts more if you get it up your sleeve though.
Cheers,
Rob
