At the weekend I got the dreaded clutch pedal go very stiff and then freed off and now goes straight to the floor with no clutch operation, I believe it is the master cylinder at fault , I have a reseal kit at hand but as I only did it a few years back I'm wondering if it's kaput ( I'm pretty sure I have never replaced it as a whole unit and only resealed it ) what options do I have for a replacement as they seem very hard to get hold of, can you use one which has the reservoir on the master cylinder and do away with the remote reservoir ? or are there any other options ?
Just reseal it. Hone the bore with a roll of 1200 grit wet and dry in brake fluid. You could try silicon fluid next time too to stop the cyliders
corroding. Works ok on my p6 which has a common reservoir for both, but do the slave rubbers too. The P6 also uses the same cylinder...
Also check the circlip groove is good. Have had a couple of pedal rods fall out which is not fun...
After resealing the master and cleaning up the bore with 1200 wet and dry ( was not that bad ) I refitted and found the slave on it's last legs also , there was brake fluid behind the rubber boot, which was not obvious until the boot was moved , I'm gonna get a new slave and reseal the old one and keep as a spare, what's the best place to get a slave, maybe a land rover one
Galileo wrote:Make sure you get the same 0.875" bore for the slave that matches the 0.625" master, I've read about 1" bore LR slaves accidentally being used.
Edit: May I suggest Chris Witor? Everything I've had from him has been good quality so far.
