1933 Rolls Royce Phantom 2 Continental
HQentity
#1 Post by HQentity »
Hello all!
I was on my travels on the internet this afternoon and found a 1933 Rolls Royce for sale, beautiful (insanely expensive) vehicle.
Interestingly, the steering wheel has most of the engine controls, including a choke of sorts, and very interestingly, a timing adjustment. I'm guessing this is before distributors had self-advancing timing. Can you imagine racing one of these?!
>>>>>Link here to the vehicle.<<<<<
HQentity (Kyle)
Mahesh
Re: 1933 Rolls Royce Phantom 2 Continental
#2 Post by Mahesh »
Nice link, nice read.
I wonder if they made bespoke rubber bushes or did they go Superflex to fit and forget.
Karlos
#3 Post by Karlos »
Mahesh wrote: I wonder if they made bespoke rubber bushes or did they go Superflex to fit and forget.
A Gentleman would not enquire about another's bushes.
If he did, he he would be told they were "sufficient".
#4 Post by tony g »
:lol:
Galileo
#5 Post by Galileo »
And available in black only...
#6 Post by soe8m »
Only the older types I heard.
Sundowner
#7 Post by Sundowner »
HQentity wrote:Hello all!
My '21 Model T Ford has both a spark advance/retard lever and the throttle lever on the steering column and isn't all that hard to master. But with gears selected by pedals (no gear lever) and a manually operated rich/lean mixture rod under the dash, then it makes the whole driving experience almost unpleasant. Oh, and no indicators either (nor a brake light). So you can imagine that there's quite a lot going on when driving a T.
I'm presently building a 1915 T Ford Speedster and to overcome some of the difficulties, I've installed a distributor with centrifugal spark advance, a set and forget Stromberg OF carb and a foot throttle. There's not much I can do about the planetary/epicyclic gearbox with its pedals though.
The pics show my '21 Tourer, a chart for beginners and another pic of a Speedster looking close to how mine should look when finished.
I hope with the changes I've made to it the Speedster will be much more fun to drive.
Cheers,
Rob
7425260_orig (802 x 600).jpg (214.01 KiB) Viewed 2087 times
Mahesh
#8 Post by Mahesh »
Looks good, the chart does offer a lot of insight.
The Speedster would look better in Triumph Inca Yellow :D
#9 Post by Carledo »
Just needs a blown and injected 500cu in V8 and a TH400! And maybe a drop of nitromethane!
Where I used to live in Slough, there was a famous local eccentric whose "daily driver" was a 1917 Dodge bros racing car. 9 litre 4 cylinder engine, chain drive, girder chassis, bonnet , bulkhead, 2 seats and a tiny cylindrical fuel tank. And NOTHING else! It was VERY loud and surprisingly quick!
