Sprint custom made clutch hose size?
Galileo
#1 Post by Galileo »
Decided to get a replacement custom clutch hose made up for an aftermarket standard master cylinder to slave. The car is away having it's annual ministry poke and prod so I can't check the length of the hose, anyone know off the top of their head what it is?
Price is £24.95 delivered, which seems so reasonable that I'm suspicious that I've got something wrong, so for a sanity check I'm looking for a master cylinder end swivel male 3/8" x 24 UNF to 7/16" x 20 UNF at the slave?
tonybsa
Re: Sprint custom made clutch hose size?
#2 Post by tonybsa »
You have the right cylinder,they were originally manufactured for Hillman Imps,clutch and brake mastercylinders.As long as the bore size is .625" you will be fine.
I use these on my racebike.I am looking at drilling and tapping out the small hole to make it the same size as a Sprints.
Galileo
#3 Post by Galileo »
Thanks for the thumbs up there!
