Triumph Toledo starter
Hi need a bit of advice, have put a 1500 dolomite engine in my Toledo and am struggling to get it started. Starter turns over but a little slowly could this be a wiring issue or starter issue any ideas happily received cheers Carl
Re: Triumph Toledo starter
I've moved your thread here.
- Triumph1300
Which starter, and flywheel combination have you ended up with?
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
Dolomite 1500 starter with solenoid attached and its the flywheel that was on the dolomite 1500 engine when I got it.
I have a recon 1500 Dolomite starter on the shelf here if it transpires you need one...
Stourbridge or TDCIR...
If it is slow turning over and the battery is sound, make sure you have a good engine earth before blaming the starter.
