compression
73sprint
compression
#1 Post by 73sprint »
I think the sprint head i am rebuiding has been skimmed twice. It measures 119.6 mm from the cam journal to the head face. What happens if it runs with too much compression ? All standard sprint engine and carbs by the way.
Re: compression
#2 Post by soe8m »
More hp.
Re: compression
#3 Post by Jon Tilson »
Risk of detonation and piston failure...
Very common on Sprints especially with modern fuels and hotter climes...
Use a thicker head gasket. Be very careful with ignition timing and listen for "pinking" when running.
Re: compression
#4 Post by soe8m »
Skimming in total 1,5mm of the head and engine deck together makes me use octane 98 at a minimum. When a head is skimmed the normal way 2 times i would not worry. If the engine then pinks there's something wrong with your mixture or you have ignition wear. My advise would be use a normal gasket and enjoy the few hp's more.
