Carb mounts
Re: Carb mounts
Yes, I believe they are...
Re: Carb mounts
Yes they are.
Re: Carb mounts
And very good they are too!xvivalve wrote:Yes, I believe they are...
1980 Dolomite 1850HL Auto
1977 Dolomite 1500
1977 Dolomite 1500
Re: Carb mounts
Except those are TR7 or Sprint ones for HS6 carbs in the pics. and I have to say again sawing the studs off is
an unnecessary and damn tedious business for which there is no need if they were made properly to start with.
Re: Carb mounts
Jonners.
Stud length has been altered.
If I'm not told off a problem how can it be changed.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
- trackerjack
Re: Carb mounts
That breather hose is well past its sell by date.
Re: Carb mounts
Never mind the breather hose or the fact that the heater pipes are not connected. Just gaze in awe at the carb mounts with their hand-shortened studs.trackerjack wrote:That breather hose is well past its sell by date.
Re: Carb mounts
If insulators are used the stud length is correct:
http://sucarb.co.uk/insulating-manifold ... asket.html
Re: Carb mounts
I have never seen these on a TR7 or Sprint.
I just used decent gaskets when I have done these. We did complain about the over long studs before too for Phil's benefit.
I cant explain why you weren't told this earlier.
Re: Carb mounts
Its the vacuum hose for the servo and yes it has been replaced!trackerjack wrote:That breather hose is well past its sell by date.
Russ Cooper
Dursley
UK
Dursley
UK
Re: Carb mounts
The phenolic spacers would be a good idea if airbox to master cylinder clearance wasnt so tight (sprint).
