Column bush plate
Steve28
Column bush plate
#1 Post by Steve28 »
Im now putting my 1500tc back together after some welding work and the sealer around the column lower bush plate as all but dried up and turned to dust, so what a good replacement for the old sealer ?
1973 yellow Sprint L reg
1979 1500 SE T reg
1979 1500 SE V reg
1980 vermillion 1500hl W reg
1975 green 1500tc auto P reg
1973 Brown Toledo 2 dr L reg
1973 Green Toledo 2 dr L reg
1983 White Toyota Tercel 4x4
1987 Brown Toyota Tercel 4x4
1988 Blue Toyota Tercel 4x4
1999 Toyota Corolla vvti est
2005 Ford ranger thunder XLT
Flyfisherman
Re: Column bush plate
#2 Post by Flyfisherman »
Cannot beat a small bead of silicone sealent around the outer edge of the retension plate.
Paul
GTS290N
#3 Post by GTS290N »
I would use old-style windscreen sealant, it never hardens. Available from all motor factors.
#4 Post by xvivalve »
The original material is very similar to a product called Bostick.
