1850 water pump
Posted: Tue Sep 06, 2016 8:58 pm
by AlanH
I have managed to get the water pump out but the brass cage has stayed put.
It seems to be a very tight fit and not leaking so would it be OK to leave it in place?
If I do need to get it out what are my options? I don't have a slide hammer, the Wiki mentions an extraction tool but the page is empty.
Re: 1850 water pump
Posted: Wed Sep 07, 2016 10:17 am
by Jon Tilson
Buy a slide hammer....
Seriously they cost very little and for the amount of use you will get just on the front hub grease caps they
are well worth it.
Funny how 2 small or rings can be so recalcitrant.
The extractor tools cost more and are less effective.
Re: 1850 water pump
Posted: Wed Sep 07, 2016 10:20 am
by xvivalve
You don't need a slide hammer for front hub grease caps!!!! A tap on the shoulder with a wide bladed screwdriver and they are off straight away!
