Does anyone know the sizes/ spec for the water pump housing to heater hose barb?
The one I have is a bit corroded so I'd like to replace if I can?
Rimmer's etc. don't seem to list it for the sprint or TR7.
I think the hose size is 13mm/1/2" but any idea of the thread size in the housing?
Andrew
Water pump cover to heater barb size
Okay....
There are two sizes,
the early one is the same as the T2000/Viesses/GT6 water pump hosetail,
the later type is common to the TR7.
The early type is a UNF screw (5/8"UNF I think?) whereas the later is a (tapered) BSP. Both are for 13mm hoses.
