Hello all!
Does anyone know what the part number is for the tiny square plastic trim clips, that hold the metal trim on the top of the door, between the handle and the glass?! The other number I'm looking for is the bit of rubber between the subframe and the body, the furthest part of the subframe towards the back by the wheels.
Many thanks!
Part numbers
- HQentity
Part numbers
HQentity (Kyle)
Re: Part numbers
This image shows an exploded view of the subframe mountings - take your pick for the rubber bit you need: http://www.rimmerbros.co.uk/ItemImages/ ... 008485.gifHQentity wrote:Hello all!
Many thanks!
I think the trim clips you are after are 617243 - there are 20 per car.
1980 Dolomite 1850HL Auto
1977 Dolomite 1500
1977 Dolomite 1500
Re: Part numbers
If it's the same trim then Chris Witor sells an alternative that's only 38p each or £8 from Bresco for a bag of 20.
Re: Part numbers
The Rimmer's version of 617243 looks much more like the ones I have on my spare door.
http://www.rimmerbros.co.uk/Item--i-617243
...... but at £1:50 each they are a bit pricey !
