Helicoiling ?
Helicoiling ?
#1 Post by MIG Wielder »
I know Helicoiling is usually used on castings to repair stripped threads, but I've stripped a thread on my Sprint style 3/8UNF alloy wheel nut. Can this be Helicoiled ?
O.K. it has to be drilled out but there looks to be plenty of aluminium wall thickness on the sleeve.
I was wondering if there might be a problem with seizing of the new thread due to corrosion as its an alloy nut with a stainless steel Helicoil on a mild steel wheel stud ?
Thanks Tony.
trackerjack
Re: Helicoiling ?
#2 Post by trackerjack »
I have had to helicoil sprint heads where idiots torque the small 5/16 unc cam bolts to oblivion, so yes indeed it can be done but the expense of the helicoil kit would make it expensive when a new nut can be the cheapest and best route.
Rolls Royce use helicoil when new as you end up with a stronger thread.
The alloy used for wheel nuts is 2014 which is a hard alloy.
Re: Helicoiling ?
#3 Post by Carledo »
I think if it were a 7/16 nut, which are plentiful, replacing it wouldn't be an issue. But with 3/8 Sprint nuts being like hens teeth served on a bed of rocking horse poo and garnished with unobtanium, helicoiling suddenly seems like a cost/time effective solution.
My only concern is how many removal/refitment cycles a helicoil will tolerate before it stays on the stud.
geeksteve
Re: Helicoiling ?
#4 Post by geeksteve »
Carledo wrote:But with 3/8 Sprint nuts being like hens teeth served on a bed of rocking horse poo and garnished with unobtanium, helicoiling suddenly seems like a cost/time effective solution.
I may have some soon, my rear axle which I've just fitted is the larger thread..
Bumpa
Re: Helicoiling ?
#5 Post by Bumpa »
I too am looking for a full set of 3/8" Sprint wheel nuts. I don't mind steel ones. The ones sold by Rimmers seem very expensive.
Re: Helicoiling ?
#6 Post by xvivalve »
If I could be certain about the grade of aluminium alloy used, these would be in production, but as a safety critical item, I dare not!
I may have a single spare 3/8" nut Tony...
GrahamFountain
Re: Helicoiling ?
#7 Post by GrahamFountain »
Don't know what the drill size for 3/8s coils is, but would it be big enough you could helicoil a 7/16ths nut with a 3/8ths coil?
Went and looked, and the drill size for a 3/8ths helicoil is 25/64ths, i.e. 3/64th smaller than 7/16ths. So it wouldn't be safe.
trackerjack
Re: Helicoiling ?
#8 Post by trackerjack »
xvivalve wrote:If I could be certain about the grade of aluminium alloy used, these would be in production, but as a safety critical item, I dare not!
Alun I wish I could remember where I read it but Porsche 944's have alloy nuts too and the material is definitely Aluminium 2014 grade.
Re: Helicoiling ?
#9 Post by soe8m »
The designer of the alloy sprint nuts did had the rest of his working life after he left BL a career at Porsche.
trackerjack
Re: Helicoiling ?
#10 Post by trackerjack »
soe8m wrote:The designer of the alloy sprint nuts did had the rest of his working life after he left BL a career at Porsche.
What was he doing there? was he helicoiling stripped Porsche nuts :lol:
