Has anyone on the forum got experience with NODIZ for controlling ignition on a Sprint?
Pro and cons versus megajolt?
NODIZ ECU
Re: NODIZ ECU
Pro is that it does not require an EDIS module. Con is that without an EDIS module there is no limp home mode if the main unit goes fubar. Money wise they are not too dissimilar, Megajolt maybe slightly more expensive.
I'm heading down the Megajolt route if only because it has been around awhile, and there are a lot of people that have experimented with them already. In saying that, NODIZ can import Megajolt maps so...
Re: NODIZ ECU
Does NODIZ do TPS and MAP versions or just MAP. If MAP only any suggestion on how to mount a MAP?
