Starting problem 1850 with berg carbs
Posted: Tue Dec 06, 2016 7:50 pm
by Magenta Auto Sprint
Of late I have been having problems starting my 1973 1850 Auto.
I went through everything last weekend; ignition timing, points gap, new rotor arm, condensor, Dizzy cap, a new coil was fitted 4 months ago, I have petrol at the pump and in the carbs.
There is also an after market electronic igniton system fitted, not sure of make, I have 12 V on cranking and 8 V when not.
The diaphrams were also replaced 4 months ago along with the rubber gaskets between the carbs and the manifold.
The only thing I can think off now is the choke or 'cold sart' device, what problems can there be with this?
The plugs were last changed 4000 miles ago.
many thanks
Malcolm
Re: Starting problem 1850 with berg carbs
Posted: Wed Dec 07, 2016 7:47 am
by Toledo Man
Malcolm, you're not the only one with starting problems.
The only advice I can offer is to start from scratch. Make sure your ignition is 100% before moving on to the carbs. I'm seriously considering reinstating my Delco dizzy (with the points and condenser) just to get running again.
Posted: Wed Dec 07, 2016 11:35 am
by MIG Wielder
Hi Malcom, Couple of questions if you can help please.... Are the measurements of 8V and 12V on the coil positive terminal ?
If you measure the volts on the coil negative terminal while slowly turning the engine over what sort of voltages do you see there pleaese ?
Is the electronic ignition one of these "transistor assisted points" devices ? Since you have a points gap to adjust and an electronic ignition this may be the case (probably) .
Since its an early 1850 with Strombergs do you have a cermic cased ballast resistor on the inlet manifold ?
Cheers for now,
Posted: Wed Dec 07, 2016 5:28 pm
Thanks Guys,
Tony,
The aftermarket electronic ignition may be a lumenition system, it is a small box mounted at right angles to the coil,
has a red and green LED at the front. The red LED goes out when the points open if the engine is turned by hand with ignition on.
I have a ceramic ballast resistor on the inlet manifold and have measured voltages on both sides of this.
The voltages I measured were on the +ve side of the coil, I'll check the other side to see if there is a differance.
My next step is to see if if it coughs when some easy start is applied.
Malcolm
Posted: Wed Dec 07, 2016 11:48 pm
by Jon Tilson
If the ballast bypass feed is iffy you can short it out with a flying lead from battery plus to coil plus.
Only change one thing at a time...:-)
Should be better tomorrow as its milder.
Posted: Fri Dec 09, 2016 8:14 pm
An update on the 1850 (Donald) I had repalced almost everything and test everything and bypassed things etc.
I finally changed the sparking plugs and she fired up second go, I did change them less than 4000 miles ago, maybe damp I don't know, they look ok but who knows what dark secrets spark plugs hold.
Thanks again for the tips and suggestions.
malcolm
Posted: Fri Dec 09, 2016 10:52 pm
by GTS290N
Hi Malcolm, care to share what brand and model the plugs were?
Posted: Sat Dec 10, 2016 8:45 am
The old plugs were Champion N12 YCC, i don't remember buying the plugs and my local motor spares guy only sells NGK, so the plugs must have been new old stock that came with the car.
I have had the car 3 years and it was off the road for about 12 years before that, therefore they could be more than 15 years old.
Malcolm
Posted: Sat Dec 10, 2016 8:51 am
by soe8m
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
You should have started the thread with:
The plugs were last changed 4000 miles ago but are at least 15 years old.
That did save a lot of forum space.
Posted: Sat Dec 10, 2016 8:53 am
by 80Sprint
Are Champions ok for the 1850 as you should steer clear on a Sprint ?
NGK's on any car for me..
Posted: Sat Dec 10, 2016 9:00 am
by soe8m
Champions aren't that good in any car.
Posted: Sat Dec 10, 2016 9:49 am
by Galileo
:lol: We need a like button on this forum!
soe8m wrote::lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Posted: Fri Dec 16, 2016 3:55 pm
by Jon Tilson
Get a set of bosch platinums...
NOS on ebay, last for ever.
the poem goes...
NGK
are for throwing away....
