olr159w wrote:
Which means I just did the lower arm inner bushes. I can't fully remember but I think when I removed them they were the older bushes with metal plates/washers fitting on each side of the rubber bush all within the circular hole at the end of the arm.
Hello..yep, he means those.
You are not alone..I have had two Sprints that have done this.
The first Sprint I had, I replaced the bushes with the nos metal type and the wheels were spot on.
My current one however still looks rubbish on one side! I put nos in..still the same, I put Superflex Black Poly ones in..still the same.
I was getting concerned at this point. I then bought nos arms with bushes already installed from Rimmers..(my way of thinking was that maybe the mounting holes on the arms were drilled slightly in the wrong place)..and it was still the same.
No amount of shims have sorted this out.
I've come to the idea that either the mounting hole on the subframe or the hub end have been drilled slightly out of line on the affected side..
I've had to get used to it..still very annoying though.
Sorry I can't give you a constructive answer, and sorry to hijack your thread with my woes..but just trying to save you time, money and effort!
It would be great if you could find the problem..I will buy you a virtual beer!
Best of luck!
