Couple of parts queries
tinweevil
#1 Post by tinweevil »
Headlamp bowls; is there any alternative to the modern plastic ones? I have some recollection that someone found a Jag supplier still had the real steel deal, or am I imagining it? If it was a weird dream how awful are the plastic ones?
Windscreen seals; What is the latest on these? How do I tell if I've received one of the ones that don't fit.
Screen seals again; was it glycerine I read that restores rubber seals? I'd like if possible to save a rear no-trim seal.
Door seals; who has the least crap offering?
Windows inner & outer seals; same question.
Ta folks
GTS290N
Re: Couple of parts queries
#2 Post by GTS290N »
tinweevil wrote:Headlamp bowls; is there any alternative to the modern plastic ones? I have some recollection that someone found a Jag supplier still had the real steel deal, or am I imagining it? If it was a weird dream how awful are the plastic ones?
Windscreen seals; What is the latest on these? How do I tell if I've received one of the ones that don't fit. they're all the same
Screen seals again; was it glycerine I read that restores rubber seals? I'd like if possible to save a rear no-trim seal. I used glycerine (chemists shop) on my non trim rear, it stopped it getting worse and is still on the car. I hung up the seal and rubbed glycerin on it several times a day for several days, then refitted.
Door seals; who has the least crap offering? Chris Witor, tell him it's for a Dolly and front or rear
Windows inner & outer seals; same question. Chris Witor, make sure you buy his clips and tell him they're for a Dolly
Just my tuppence. :D
Ta folks
