Head lights
Head lights
Hi should the headlight backing bowls be the same for inner and outer lights[/
Just on my car on the inner lamps i dont have the backing bowls
Daveolor]
Daveolor]
Re: Head lights
Inner lights have a backless backing bowl, more of a mounting ring really, outers have a full bowl, which was originally steel, modern substitutes are plastic. New inners are not really available, but you can easily cut the back out of a tin or plastic outer to make an inner.
Re: Head lights
SteveCarledo wrote:Inner lights have a backless backing bowl, more of a mounting ring really, outers have a full bowl, which was originally steel, modern substitutes are plastic. New inners are not really available, but you can easily cut the back out of a tin or plastic outer to make an inner.
That sounds how my inners are no bowl as such,do you know if a bowl will fit ?
Re: Head lights
TBH i've never tried, why would you? But I can think of 2 reasons why not, 1) it may not fit and 2) the absence of a bowl, at least on the offside, lets more cold air into the carbs behind it. On my 2 headlight car I have actually got the cone air filter where the back of the inner lamp would be.new to this wrote:SteveCarledo wrote:Inner lights have a backless backing bowl, more of a mounting ring really, outers have a full bowl, which was originally steel, modern substitutes are plastic. New inners are not really available, but you can easily cut the back out of a tin or plastic outer to make an inner.
- Flyfisherman
Re: Head lights
a bowl will not fit due to a inner steel panel behind the front valance.
As the shortcut not showing the topic - here is the picture.
Paul
Paul
Re: Head lights
I trimmed my down to fit and using polymorph and sealant to bond it to the panel to stop crap getting in.
Re: Head lights
SteveCarledo wrote:TBH i've never tried, why would you? But I can think of 2 reasons why not, 1) it may not fit and 2) the absence of a bowl, at least on the offside, lets more cold air into the carbs behind it. On my 2 headlight car I have actually got the cone air filter where the back of the inner lamp would be.new to this wrote:SteveCarledo wrote:Inner lights have a backless backing bowl, more of a mounting ring really, outers have a full bowl, which was originally steel, modern substitutes are plastic. New inners are not really available, but you can easily cut the back out of a tin or plastic outer to make an inner.
Glad i asked the question,and didnt jump in like bull in china shop,like i usually do,hadnt thought about air flow
- Flyfisherman
Re: Head lights
thanks for your comment regarding the condition of my car - the headlight retension panels / spacer brackets are held in position via set screws and rivnuts, makes it easy to remove if required, all parts were powder coated prior to fitment.
Paul
Re: Head lights
PaulFlyfisherman wrote:Dave
Paul
that's a good idea making it re-moveable, may do some thing like that my self
Re: Head lights
When I fit my new club headlamp support panels, I will be screwing rather than welding too! It will make it a few minutes work to remove the entire pair of lights to clean behind them, an area which is almost totally inaccessible under normal "standard" conditions. This will also make it a doddle to clean and lubricate the headlamp adjusters. I will also be using self tappers and spire nuts to secure the headlamp bowls to the mounting plates, rather than the pop rivets that were originally used.
It is in our own interest to make these small design alterations, the way the factory did it was not necessarily the BEST way, just the CHEAPEST.
With more time on our hands, a bit of lateral thinking and free labour, we can do BETTER than new!
Re: Head lights
SteveCarledo wrote:When I fit my new club headlamp support panels, I will be screwing rather than welding too! It will make it a few minutes work to remove the entire pair of lights to clean behind them, an area which is almost totally inaccessible under normal "standard" conditions. This will also make it a doddle to clean and lubricate the headlamp adjusters. I will also be using self tappers and spire nuts to secure the headlamp bowls to the mounting plates, rather than the pop rivets that were originally used.
when you say spire nuts,are they small plastic clips that you then put a screw in the middle,the stag headlights are put together using that method
Re: Head lights
A Spire nut is a narrow U shaped spring steel clip with a hole in one side and a matching thread bit to take a self tapper in the other side, the U bit fits either side of the panel you wish to screw to (near edges only, obviously) A cheaper alternative to rivnuts and perfect for this job.
