Well today it appears that i solved one issue only to find i had another.
I have fuel appearing on top of my rear float chamber, i have replaced the hose and clips numerous times, fine when its running with no sign of a leak but as soon as i shut off, after about 5 mins a small amount of fuel starts appearing on top of the float chamber very difficult to see where its coming from but i do not think it is out of the hose.
Any suggestions please.
fuel issue
- tangocharlie1
fuel issue
1973 Triumph Dolomite Sprint
1972 Triumph Stag
1973 Triumph TR6
1972 Triumph Stag
1973 Triumph TR6
- Triumph1300
Re: fuel issue
Out of the overflow, as the fuel starts to heatsoak, and boil
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
- tangocharlie1
Re: fuel issue
Ok there was no obvious overflow on the rear pot, only the front one, but i found a small hole hidden behind a brass clip that is the likely culprit, not had a chance to open it up yet but guessing it's a float issue.
1972 Triumph Stag
1973 Triumph TR6
1972 Triumph Stag
1973 Triumph TR6
